| Register | SLK Products | Clubs | Garage | Blogs | Members List | Social Groups | Search | Today's Posts | Mark Forums Read |
| DIY Section Step by step procedures for common maintenance and upgrades to your SLK |
| | LinkBack (13) | Thread Tools |
| | #61 (permalink) | |
Vehicle: SLK 55 AMG
Country: Thanks: 13
Chats: 0 | Quote:
ok ...... ok ..... i'm | |
| Sponsored Links | |
| | #62 (permalink) | |
| SLK World Junior Member Join Date: Dec 2007 Location: No. California
Vehicle: 2006 SLK350
Chats: 0 | Quote:
Thanks a bunch for the photos - Green Filters arrived yesterday - installed today, took 20-minutes. Woo!!! Hoo!! go for it ladies, not difficult at all............ ![]() Back Roads | |
| | #63 (permalink) | |
Country: Thanks: 222
Chats: 0 | Quote:
| | #64 (permalink) |
| Senior SLK World Member Join Date: Jun 2007 Location: Brisbane, Australia
Country: Thanks: 6
Chats: 0 | damn.... i want to get those Green Filter... by the way does any one have pic with the 350 installing instruction? i couldn't unclipped the hoses and the air box(don't laugh at me) and I'm too scare that I'll break any clips.... |
| | #65 (permalink) |
Chats: 0 | I have a 350, so those pics comes from my 350. you will not break anything, the hoses slide right off, pull straight up, start from one end to the other and the metal clip should just come right off.
| Sponsored Links | |
| | #66 (permalink) |
| SLK World Member Join Date: Dec 2007 Location: NorthEast, US
Vehicle: 2007 SLK350 6M with AMG pkg
Country: Thanks: 3
Chats: 0 | Ynot, it seems that the SLK350 also has a 2 piece airbox cover? and that you also lift out the front piece first similar to the SLK55 cover? Your pic in the beginning of this thread only shows the main cover, right? Thanks for any clarifications. |
| | #67 (permalink) | |
| Founding Member #2 Join Date: Jun 2006 Location: Orange County, CA
Country: Thanks: 1,269
Chats: 5 | Quote:
After removing the front piece and before removing the back piece (that contains the air filters), remove what looks like a vacuum hose at the front of the back piece first, then remove the back part.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Modified R170 ant., Clear sidemarkers & parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake. | |
| | #68 (permalink) |
Country: Thanks: 3
Chats: 0 | Thanks Eddy! So I can just lift the front cover off, right? Yes, I believe there are 3 hoses that need to be pulled off, 2 big ones on both sides and one small one in the middle that you described that is located in front of the back cover. Aren't there clips that connect these hoses? Ynot mentioned that they can be easily slided off. I wonder what keeps them tight enough if they can come off so easily ? Sorry for these simple questions but I haven't try it yet since I plan to change to Green filters after I do the service A in April, but I did order them before the price go up in March in SLK store |
| | #69 (permalink) | |
Chats: 5 | Quote:
The 2 large hoses are the air ducts that lead from the front of the engine to the back piece. These can be removed by twisting the back part towards the front of the vehicle with you standing at the front of the vehicle. Do the left side first (left side as oriented with the driver seated inside the vehicle, driver side in left-hand-drive vehicles). Notice the hoses have corrugations or circular rings or accordion that allow it to be compressed to effect removal. After freeing the back end, the front end can be removed by pushing on the tab at the top and twisting side to side. There is another tab on the lower portion but the air hoses should come off by just releasing the upper tab. On the right side air hose (350 and 280), I believe there is a clip that holds a small overflow rubber tube leading from the radiator to the cooolant reservoir. BE CAREFUL REMOVING THIS CLIP. They break easily. Here's a link to how I replaced mine (see post #11 and #13ff):http://www.slkworld.com/general-modi...slk-280-a.html The air hoses are held in place mainly by friction on the rounded end and by tabs on the oval front end. The front decorative piece just lifts up. Lift from the middle part first with mild to moderate force and it will release the front end of the front piece. Do not lift way up or you'll break some clips. Next gently lift from one side of the front piece (towards the back of the front piece) to release a clip. Then work on the other side. Once the back clips have been released, slide the front piece towards the front of the vehicle and the whole piece should come off. Here's a link on my post about breaking the clips: http://www.slkworld.com/amgs/4227-bo...oke-clips.html
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Modified R170 ant., Clear sidemarkers & parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake. Last edited by etyu; 02-22-2008 at 06:45 PM. | |
| | #70 (permalink) |
Chats: 0 | thanks eddy.
| Sponsored Links | |
| | #71 (permalink) |
Country: Thanks: 3
Chats: 0 | Thanks for the details Eddy! Now I am afraid to break those clips even though the cover can still be stable without them, I would still feel bad (kind of the same feeling I get when I scratched the bottom of my front bumper). So looks like the front cover is similar to the one in the SLK55. May be I should try Bill T's method of removing the 2 covers as one piece. Last edited by toySLK; 02-23-2008 at 12:37 PM. |
| | #72 (permalink) |
| Elite SLK World Member Join Date: Jan 2008 Location: Germany
Vehicle: 09 SLK AMG 55
Country: Thanks: 20
Chats: 0 | As a future new owner of the 55, will I get any grief from the MB dealer if I change to the "Green" filter? I wouldn't think so, but are there any warranty issues? |
| | #73 (permalink) | |
Chats: 0 | Quote:
I put the factory filters back in when I take it to service and tell them not to change it b/c my K&N's were taken (long time ago) and replaced with factory ones, I didn't notice until six months later when I took it out to clean. I'd complained but they dealer did nothing. It was my fault too for not noticing until much later, it happened to a couple of my friends as well. I'm not afraid of warranty, I'm afraid they might take it.
| | #74 (permalink) | |
Chats: 5 | Quote:
If you break them, no biggie. Just apply some weather strip foam instead to dampen any vibrations as shown on the aforementioned post about breaking the clips.
| | #75 (permalink) |
| SLK World Member Join Date: Feb 2008 Location: Texas
Vehicle: 2008 slk 350 Mars Red
Chats: 0 | just ordered mine the other day after i bought a mars red 2008 slk350 about a week ago. just wanted to drop a line and say this is a very nice community. |
| Sponsored Links | |
| | #76 (permalink) |
Chats: 5 | WELCOME ICEBORNE!
| | #77 (permalink) | |
Country: Thanks: 3
Chats: 0 | Quote:
![]() Ynot, do you have a secret technique of removing the front cover of your 350 ? How come you never mentioned breaking yours. I remember you recommended just pulling up the cover and you said it won't break anything ? or was that just the back cover? | |
| | #78 (permalink) | |
Chats: 0 | Quote:
| | #79 (permalink) |
| Elite SLK World Member Join Date: Feb 2008 Location: Yukon, OK
Country: Thanks: 92
Chats: 0 | Well, I just installed the "Greens" in our SLK 280 in less time than it took to read this thread. And I'm NOT a mechanic -- oh no! I'm the only guy I know who ever fouled up an oil change! In any event, here's a tip or two. In removing the front plastic cover, unsnap it from the outboard connection points with the rear plastic cover by bending the front cover up gently at the rear outer edges. Then just lift up. The hoses disconnect by just pulling off. No clamps. Then, remove the clip that holds the back of the rear plastic cover on, and just pull the rear cover upward. After you've removed the rear cover (which has the air boxes underneath) place this cover upside down on a towel or blanket to avoid scratching. After unscrewing the air box screws to get to the filter, spray a bit of WD 40 on the threads. They go back in much easier. When it's time to snap the rear cover back on, locate those round rubber bits that the clips attach to, and rub a bit of paste wax on them. The back cover will snap back on much easier that way. Just push the hoses back on. Clip the two middle clips of the front cover on, then snap the outboard clips. Then you are done. My car has less than 2K on the odo, and already the air boxes were dirty. They are going to need cleaning every few months, I fear. Thanks to all for the advice. Haven't driven enough to get the ECU reset, but I can tell that the engine is quieter. |
| | #80 (permalink) |
| Don - Founding Member #4 Join Date: Jun 2006 Location: Virginia USA
Country: Thanks: 227
Chats: 0 |
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ----------------1----------------- --------SLK 55 ///AMG--------- 19s AND ALL THE GOOD STUFF |
| Sponsored Links | |
| Bookmarks |
| Help With Green Filter Install!! | MDS | Performance MODS for the R171 | 18 | 02-17-2009 01:21 AM |
| Green Filter Orders | WhiteRabbit | SLK R171 General Discussion | 36 | 07-03-2007 09:11 PM |
| Question on green filter install | bob44 | SLK R171 General Discussion | 6 | 07-01-2007 03:30 PM |
| Green Filter | Elwood | SLK R170 General Discussion | 3 | 04-22-2007 05:27 AM |
| KN Filter/Green Filter | jfsully | SLK R171 General Discussion | 1 | 01-28-2007 11:10 PM |
