Fix for Code PO410 - 2001 SLK 230 - Mercedes Benz SLK World Forum
Go Back   Mercedes Benz SLK World Forum > Technical Information > DIY Section
DIY Section Step by step procedures for common maintenance and upgrades to your SLK
SLKWorld.com is the premier Mercedes-Benz SLK Forum on the internet. Registered Users do not see the above ads.
Old 03-06-2010   #1 (permalink)
Scoope
Vehicle: 2001 SLK 230 - Red
Other Toys: Boat
Question Fix for Code PO410 - 2001 SLK 230
I have a 2001 SLK 230 Kompressor. The check engine light stays on. The code for this is P0410. Can any of you guys give me a step-by-step fix for this problem.
Scoope
View Scoope's Photo Album Scoope is offline   Reply With Quote
Old 03-06-2010   #2 (permalink)
Todd157k's Avatar
Vehicle: 2006 SLK55
I'll look it up in the repair manuals. For now, I found this: (although for GM, OBDII codes are the same)
What does that mean?
The P0410 code refers to the emissions system. The AIR pump puts air to the exhaust to lower emissions. It takes in outside air and pumps it through two one-way check valves into each bank of the exhaust.
About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in climates with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
Symptoms
Possibly symptoms include:
• MIL illumination obviously
• Hesitation on acceleration
• Noise from a bad/stuck AIR pump
Causes
A code P0410 may mean that one or more of the following has happened:
• Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump
• Blown AIR pump fuse due to freezing up
Possible Solutions
Note: There is a technical service bulletin (TSB) regarding this code for a number of GM models. The TSB calls for the replacement of the AIR pump and the installation of a new secondary injection hose. The TSB can be found on this ACDelco site.
Additionally, if you simply replace the AIR pump the problem may return again (and again). If you replace the pump, also clean out the hoses and replace the one-way check valve. If this is on a GM model that the TSB applies to, follow those instructions in the link above. In a few cases, people have put a small hole in the rubber cover on the pump which allows any water to drain out.
Also, please note that this may be covered under the emissions warranty on the vehicle. If your vehicle is out of bumper-to-bumper warranty, check if the emissions warranty is still valid!
• Replace the AIR pump AND one-way check valve
• Test and clean the AIR pump AND test and replace the one-way air check valve
• Replace the AIR pump inlet hose
• Replace the AIR pump fuse (found under the hood)
2006 Mercedes CLS500
2004 Corvette Z06
2012 Dodge Ram
2001 Honda Goldwing
1967 Triumph Bonnie
View Todd157k's Photo Album Todd157k is offline   Reply With Quote
Old 03-06-2010   #3 (permalink)
Vehicle: 2009 SLK 55 AMG
scoope,
Thanks for being a supporting member!
And finally, if you find something useful on your visit here today, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! Thanks!
Premium 1, Multimedia, Lighting packages
Llumar (Clear Bra) Paint Protective Film
OEM MB Plexiglass
Clear Side Markers w/amber LED bulbs
LED Parking and LED License Plate Bulbs
View jbanks15's Photo Album jbanks15 is online now   Reply With Quote
Old 03-06-2010   #4 (permalink)
Todd157k's Avatar
Vehicle: 2006 SLK55
Sorry Scoope, the manual just refers to diagnostic equipment. Kind of a POS manual that I got of fleebay.
2004 Corvette Z06
2012 Dodge Ram
2001 Honda Goldwing
1967 Triumph Bonnie
Old 06-02-2012   #5 (permalink)
SLK World Junior Member
check the engine on the passenger side front.There are a couple of vacuum hoses coming from under the plastic front engine cover.Remove the cover and check the hoses,also the little canister check valve my be rusty inside.You may need to replace some brittle hoses.make sure you put the hoses back on the right way.I think this area is your emissions and will send codes.
View bobbo60's Photo Album bobbo60 is offline   Reply With Quote
Old 06-02-2012   #6 (permalink)
Vehicle: 2003 SLK320 23,000 miles
Contact me at len@sokoloff.com if you would like to join our NC/SC SLK Group. We're up to 50 members now.
Len
Len
2003 SLK320 27,000 miles
1959 220S Cabriolet
1983 240D 348,000 miles original owner
1999 E300D 170,000 miles
View sokoloff's Photo Album sokoloff is offline   Reply With Quote
Old 08-12-2012   #7 (permalink)
For me the P0410 was caused by a corroded air pump check valve.
My original valve part # is 0021402860. That was replaced by a newer 0021406860.
I found an older check valve 0001407860 for $20. Tried it out for several weeks and the P0410 is gone for now. Let's see how it goes. If the older valve 0021406860 doesn't work, I will go for the newer 0021406860.
To remove the valve, you will need a 27mm or 1-1/16" low profile wrench.
View nk_400's Photo Album nk_400 is offline   Reply With Quote
Old 08-12-2012   #8 (permalink)
Passionate SLK World Member
Der Flieger's Avatar
Vehicle: silver/red 06 350
Other Toys: 09 Mazda 6 and 06 Mazda 3; fly B767-300ER
Coincidence....
http://www.slkworld.com/general-disc...ites-dust.html
FUN 4 2
View Der Flieger's Photo Album Der Flieger is offline   Reply With Quote
1997 slk 230 intermittent limp mode peteslk SLK R170 General Discussion 2 11-04-2011 06:56 PM
2001 SLK 230 Kompressor BLUE 84xxxmiles $10500 psikh SLK Cars For Sale 1 08-31-2009 06:42 PM
SLK 10th year special edition Zut SLK R171 General Discussion 45 02-25-2008 01:47 PM
Powered by vBulletin Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226
