Go Back   Mercedes Benz SLK World Forum > Technical Information > DIY Section
DIY Section Step by step procedures for common maintenance and upgrades to your SLK
Old 12-07-2009   #1 (permalink)
Vehicle: 2007 SLK 280
Other Toys: Commercial Pilot
Default Removing cd changer
OK, I want to remove the CD changer taking up all of the glove compartment in my 2007 SLK. I looked at some of the other posts and understand (I think) about the hidden catches and latches at the top.
The question I have is what do I do with the disconnected fiber optic MOST cable? I'm guessing that I need a coupler of some sort to connect the input and outputs together so that the ring stays intact. Does anyone know what this part is?
Any other advice about getting this part out?
I have really enjoyed that my main (COMMAND NTG2) display unit reads MP3 DVD's and stores a huge collection of music. That plus the aux input jack in the glove compartment means that I'm not wanting for music (plus I have Sirius). So the changer can go and I can get my glove compartment back.
Thanks!
Francis Govers
2007 SLK 280 "Mars Red"
Fort Worth TX
View SpaceDuck's Photo Album SpaceDuck is offline
Old 12-07-2009   #2 (permalink)
Donation Level 8
There was a post on using the coupler to restore the MOST fiberoptic I-O connections. This was awhile ago. DAnsSLK/UK-C200/Admantium may know and prolly give you the part number.
In the meantime try the Advanced Search feature and see what info may be out there.
I'm glad your COMAND can read mp3's on DVD as my 2008 head unit will not (confirmed by using other members' burnt DVD this past weekend). Not a biggie for me as I rarely listen to the radio nor music.
Pewter(cubanite silber)/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package
Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Modified R170 ant., Clear sidemarkers & parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake.
Old 12-07-2009   #3 (permalink)
Founding Member #7
mtiede's Avatar
Wow, that sucks.
Old 12-08-2009   #4 (permalink)
On the DVD MP3 issue, I might mention that when I put a DVD with MP3's in the unit, it first says "CD ERROR" and then it just starts working - there is a few moments of disk reading, and then it seems to just work fine - I get a list of folders on the disk and I can select from that. I have about 600 songs or so on the DVD and its only half full. But I do get an error message first.
I found a you-tube video from itronics on removing the CD player from the SLK but it does not say what to do about the fiber optic loop - the video is about adding the bluetooth interface to the SLK.
Old 12-09-2009   #5 (permalink)
I go by many names...
Silver Supporter
Bleen's Avatar
Vehicle: 2005 SLK 350
Donation Level 3
Chats: 3
Send a message via Skype™ to Bleen
? I just removed my cd changer and left the cables there, no add on or cap... why is it needed?
View Bleen's Photo Album Bleen is offline
Old 12-10-2009   #6 (permalink)
With the command system, all of the audio compnents are on the MOST fiber optic network. This is a ring type network - each component has an input and output, and the entire ring must be intact for it to work. Taking out a component (like the CD Changer) breaks the ring and nothing will work unless the ring is joined again with a coupler.
Old 12-10-2009   #7 (permalink)
aka John
Vehicle: RHD Jasper Blue C200K Coupe, RHD Jasper Blue SLK55, LHD Black SLK350
Donation Level 7
Chats: 1142
Hmm, missed this post. SpaceDuck is right, if you have any device other than the CD changer on the bus, you need to couple the MOST fibers to keep the loop intact. I'm 99% sure that the current part number for the fiber coupler is A0005454484.
Life is good - enjoy it with the top down!
View UK-C200's Photo Album UK-C200 is online now
Old 12-10-2009   #8 (permalink)
Silver Supporter
Bleen's Avatar
Donation Level 3
Chats: 3
Well, I just have an audio 20, and it still works with the ring open ;-)
How do I put in a cd changer jhorsfield Where to get R170 SLK Items 11 07-07-2009 08:14 PM
CD changer dilema.... lramin SLK R170 General Discussion 8 06-09-2009 08:09 AM
Removing CD Changer in Trunk. FreddieR170 General Discussion 2 05-20-2008 01:20 PM
Six Disc CD Changer - Who Uses It? -1- SLK R171 General Discussion 33 06-02-2007 10:18 AM
Would like a CD Changer SLKman Where to get R170 SLK Items 0 11-08-2006 09:55 PM
Powered by vBulletin Version 3.8.5
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135
