I have the MB bluetooth module plugged into my center storage area. I just upgraded my cellphone from a motorola E815 to a new motorola Droid X. I successfully paired it to the system and I can speak and be heard. The problem is that with the older E815 the address book and received and dialed calls were loaded and could be accessed. Now with the Droid X there is no address book loading nor are the dialed or received calls available. My blackberry has the same issue. I never had access to the SMS function on the screen as it has been grayed out and not selectable. Any ideas would be appreciated.
What MB cradle do you have? Can you advise the part number?
__________________ Many many Mercedes cars, all with comand To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts.
Sorry for the delay. I have the blue tooth puck. The dealer says the part number is 67875869. My Droid X will pair to it just fine, as will my Blackberry. One at a time of course. But neither the Driod X nor the Blackberry will load the address book or will the show dialed and received calls.
