| Caring for your SLK Detailing and Car Care Tips |
Vehicle: SLK55 2006
Country: Thanks: 24
| What kind of Oil do you use, and do you agree with changing oil more frequently than MBZ reccomends? I use Lubromoly in my other cars, which can run over 7000 miles, but i always change it around 3000 miles. Should i do the same for the SLK? do they use special 'break in' oil for those first 10k miles on the AMG engine? or should i change it earlier? Would it just be a waste of oil? any tips on performing the oil change (anything to do to preserve warranty?) |
Country: Thanks: 96
| Hey mate with the oil i would only use the Mobil 1 stuff MB recommends if you want to keep the warranty its a must. With the times between changes i don't bother on mine i leave it up to the computer but you can change it whenever you want to mate about 3000 sounds like a good number to me so i would stick with it. No fancy oil gets used in it at all mate so not to worry about that its just the standard stuff. Only tip is remember that there are 2 drain plugs and if your down there maybe consider changing the transmission fluid also but you do need to pump that back in so it might not be so easy.
Vehicle: ///AMG
Country: Thanks: 17
| In the big 55 engine I think oil will last forever.. well maybe not literally. oil temps never seem raise even on silly hot days racing round the track. It's certainly not a tiny highreving sportsbike engine which also share the oil with the trans. then I'd change it every 3-5k
Country: Thanks: 54
Country: Thanks: 376
| The service advisor at the local MB told me to change the engine oil/filter following what the MFD tells you. Changing it sooner, according to him, is a waste of money. I now have about 5100 miles and on checking the oil, it is a nice light to medium brown color and not dark, after wiping from the indicator stick.
Country: Thanks: 135
| I changed mine at 4000 miles, a year of ownership, even though the service manager said it wasn't necessary, at the rate I'm driving, it'll be 3 years before my first oil change, I don't want to wait that long, for $100 bucks/year it's great insurance, less than my other vehicle at $30/3 months. Only Mobil 1 for my car.
| | #8 (permalink) |
| I think the manual actually says something like change it when the MFD says or 1 year which ever comes first. (but its been a while since I read the manual ) |
| | #9 (permalink) |
Vehicle: 2006 Slk 350
Country: Thanks: 3
| im due for an oil change in the next month or so, thats when the mfd will tell me. at 11k miles. Mobil 1 synthetic oil is good from 10-15000 miles. Just go by your mfd, it knows the oil! |
| | #10 (permalink) |
| SLK World Junior Member Join Date: Aug 2008 Location: Winter Springs Florida
Vehicle: slk350
| I have only used Mobil 1 for all cars. Hard to get out of the routine 3000 miles/change. New technology allows for longer. Stick with the mfd. |
| | #11 (permalink) |
Vehicle: SLK 55 AMG
Country: Thanks: 6
| Just for your information, i've asked to MB Europe why my dealer may not use Mobil1 for AMG engine (it was Castrol). The answer has been (from MB europe): "The car dealer is free to select for an SLK AMG, one of the 0w40 or 5w40 listed within the following list". Note : i've translated the original french answer. I've used another car dealer, which use Mobil1 (which has been recommended by Dan, but also by AMG during my visit). However, i'm quite confused because it seems that Mobil1 is not so mandatory in MB network. Here is the 2 pages of the list: ![]()
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ------Michel------ -SLK 55 AMG 2005- |
| | #12 (permalink) |
| SLK World Junior Member Join Date: Aug 2008 Location: Atlanta,GA
Vehicle: 1999 SLK 230
| I use Mobil 0-40 and I will take it out to 8,000 miles even though the oil should be good to 10,000 miles.I really don't put a lot of miles on the 1999 SLK 230 anyway...2-3000 per year...but I will change the paper oil filter at 4,000.(just to be safe since it's not fleece) I don't get the change oil on a calendar basis,anyway.The shelf life for oil has got to be many,many years.What diiference should it make if the same oil sits in the crankcase? If you're driving the car,combustion deposits,etc,get in the oil,of course.If the car sits a week,how does that contaminate the oil? When you eventually drive the car,you should boil off the bad stuff(short trips being the exception).Correct me if I'm wrong. best regards,ch7ckc |
| | #13 (permalink) |
| SLK World Member Join Date: Apr 2008 Location: Overland Park, Kansas
Vehicle: 2004 SLK320 black on black
Country: Thanks: 6
| The dealer who sold me my 2004 SLK320 told me not to worry about it until the A service... in about 9k more miles! Is this wrong? |
| | #14 (permalink) |
| Elite SLK World Member Join Date: Jan 2007 Location: Peoria, AZ
Vehicle: 07 SL 550 Mars Red
Country: Thanks: 31
| I follow the manufactures and use Mobil-1 do mostly highway driving and have changed it for the second time at 24K miles 12k each change and the computer has never told me I was due yet. I have been using this oil for years and had an SC 3.6 Bonneville that had 115 K on it was still going strong. This new synthetic oil is not what our fathers used.
__________________ GENE ---- See My Pic's To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. SL 550 Mars Red |
| | #15 (permalink) |
| Elite SLK World Member Join Date: Feb 2008 Location: Yukon, OK
Country: Thanks: 39
| I also use Mobil-1 as recommended by Mercedes. Also, I change oil twice as often as recommended. In other words, when the "miles until service" on the screen are approximately equal to my miles driven since last change, I have the oil changed. Most of my driving is suburban. We have a very dusty climate.
__________________ The SLK -- What the SL was supposed to be. |
| | #16 (permalink) |
| SLK World Member Join Date: Aug 2008 Location: Miami Florida
Vehicle: 08 SLK350 E10
Country: Thanks: 12
| I read something many years back (10-15) that stated synthetic was good up to 25k miles. So I personally, not this forum's recommendation, change it the 1st time at 1,000 miles and then every 10k miles (10,20,30etc) thereafter. It's easy to remember 10x. I have been using this method for my last 6 or so cars and had great success, though I rarely keep a vehicle more than 2 years. FYI, the 08 SMART car in my avatar is recommending the 1st oil change at 10k miles and the computer on the 07 X5 4.8i I sold a few months ago recommended it at 14k miles - though I decided otherwise and went and did it my way at 1k miles. I ALWAYS USE MOBIL1 OIL + FILTER!!! |
| oil | mazeka | SLK R171 General Discussion | 19 | 09-02-2008 08:59 PM |
| Quick question, oil gauge shows 9.0L after oil change | cyberdrakon | Ask DansSLK | 8 | 03-06-2008 01:45 PM |
| SLK 230 Motor oil and oil filter | hellfire | SLK R170 General Discussion | 4 | 11-28-2007 06:50 PM |
| Changing Engine Oil Type | SiLK | Ask DansSLK | 5 | 07-02-2007 12:32 PM |
| What oil to use | oscy | Caring for your SLK | 18 | 04-24-2007 09:15 AM |
