Go Back   SLK World Forum > General Discussion about Mercedes Benz SLK's > Caring for your SLK
Caring for your SLK Detailing and Car Care Tips
www.windrestrictor.com
Old 03-01-2008   #1 (permalink)
SLK World Junior Member
Default Haze from using cleaner wax - HELP!
Tried to use a cleaner wax on the front of the car (it's black) and now I've got a haze that I can't get off. HELP and thanks!
View Midnight Son's Photo Album Midnight Son is offline   http://www.slkworld.com/Boss Key
Old 03-01-2008   #2 (permalink)
rlbawk's Avatar
Vehicle: 2007 SLK55 AMG
Other Toys: 2006 BMW 325 Convert
I had the same issue on my car once, luckily it was only a small are on the trunk lid. I bought some Meguiers NXT wax and it took care of the haze and looks incredibly wet and deep when you're done. I use polishes from Griot's Garage but I love the NXT wax to follow it with, but the wax alone should help you out.
View rlbawk's Photo Album rlbawk is offline   Boss Key
Old 03-01-2008   #3 (permalink)
Senior SLK World Member
jfsully's Avatar
Vehicle: SLK55
Send a message via MSN to jfsully
You might try a Quick Detailer...like Meguiars ultimate Quick Detailer.... the haze may be residue left over from using too much product.
For an OTC "wax" NXT 2.0 does a good job. (I'm more of a Carnauba fan and use Pinnacle, Zymol, DoDo and Chemical guys)buffing
2006 Obsidian SLK55 w/030 package
2000 BMW E-39
1985 BitterSC
View jfsully's Photo Album jfsully is offline   Boss Key
Old 03-02-2008   #4 (permalink)
All in one "cleaner waxes" are notorious for eventually leaving a "haze" on the finish, that is particularly noticeable then the surface is viewed from the side under bright light. A simple clay bar use may resolve the problem. If not, use of a random orbital buffer with a fine abrasive cleaner will fix it.
View Dolebludger's Photo Album Dolebludger is offline   Boss Key
Old 06-26-2008   #5 (permalink)
Vehicle: 2003 C240 4Matic
Other Toys: 1998 JEEP Wrangler
What you need to remember is, paint cleaner is like liquid sand paper. It is called a paint cleaner because it is made to remove minor paint imperfections such as swirl marks, stubborn bug and bird shit... those kinda things. The light swirling that you experience may be because you used too aggressive a grit, resulting in swirl marks just as if you polished your car with a fine layer of dust on it. If the swirling is deep enough, you might want to try out the finest grit paint cleaner then simply polish the car.
View Whosdis's Photo Album Whosdis is offline   Boss Key
The Following User Says Thank You to Whosdis For This Useful Post:
Old 06-27-2008   #6 (permalink)
Absolutely! I think the haze the OP speaks of is merely built-up dirt in the wax finish, caused by the fact that a combination cleaner/wax had been used. These combination products don't adequately remove the dirt before laying on the wax. Cleaning this up by buffing with an abrasive product requires only the very finest abrasive cleaner. Abrasive cleaner, BTW, can be made even finer by mixing some liquid carnauba wax containing no cleaner into the abrasive polish. Another cure might be a washing with Dawn dish washing detergent in the water, in very low concentration.
After the old dirty wax is cleaned off, I recommend a two step cleaner/non-cleaner wax combination. For the cleaner, I recommend Autoglym Radiant Wax Polish. Strange name, but it is really a non-abrasive chemical cleaner that also works as a glaze by hiding minor swirls. For the wax, I recommend Autoglym Hardwax1. It has no abrasives or cleaners. Both are easy on -- easy buff off products. Autoglym products are recommended by the likes of Rolls Royce, Aston Martin, and the Royal Family of England (really). And use of these will not cause the haze to return.
Wash; Wax day! Doombot! SLK R171 General Discussion 5 09-18-2006 10:38 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
