| Caring for your SLK Detailing and Car Care Tips |
| SLK World Member Join Date: Apr 2007 Location: Thousand Oaks, California
Vehicle: 2005 SLK55 AMG
| Has anyone had any luck cleaning behind the buttons on a Comand Nav if they are sticky? Seems like something(coke or other sticky beverage) was spilled from the cup holder down onto the Comand buttons. They are really sticky and have to be pushed really hard to unstick them each time I want to press one. Anyone had the problem and resolved it? Thanks in advance for your help! |
Country: Thanks: 96
| Ouch Try some warm water on it you cant actually get it wet but just use enough water to get a cloth damp then try and clean it up. Don't use any detergents or similar because it will ruin it. You should probably be OK but if the coke or whatever has got behind the buttons then your going to need a new headunit. Maybe you should avoid using the cupholder again in future since a headunit will cost you in excess of a grand.
Country: Thanks: 376
| You might try a damp (not soggy wet) baby toothbrush and gently scrub at the edges of the affected button(s) and wipe the bristles often unto a clean dry cloth/cotton towel to see if the bristles will pick up the sticky stuff. Have a small cup of clean water handy so you can dip the bristles and wipe to almost dry for the next try. Repeat cycle as often as needed. Work on one edge at a time. Let us know if you're successful.
| SLK World Member Join Date: Jan 2007 Location: Connecticut
Vehicle: 2005 MB SLK 350 Everest Green Metallic (6 speed manual]
Country: Thanks: 2
| I would like to replace the cup holder as I will never use it. Is there a covered holder or anything else that I can put in its place? |
| There's a storage unit with a cover that lifts upward that can fit instead of the cupholder. It is from European spec R171. Part No. A 171 680 00 52 9116 (last 4 digits is for black color). This is quite small and is good for one pair of medium- to small-sized sunglasses or a radar/laser detector.
| I tried the tooth brush, and it got some of the stuff out, but my fear of getting too much water into the head unit held me back. Then I tried a thick piece of paper, like a heavy card stock, cut it into little strips, applied a tiny bit of 409 to the corner, and while holding the button down squeezed the paper in between the button and the button hole. It seems to have worked. Lots of brown stuff was on the paper once I pulled it out, and I just used a new piece each time. Seems simple, but the buttons are better now! |
| | #8 (permalink) |
| Thanks joelreznick for that tip and technique.
| Can I add Steering wheel gearshift buttons to my SLK? | solidtechchris | Help and Support | 1 | 10-17-2008 04:03 PM |
| few dumb questions regarding comand and nav | alx | SLK R171 General Discussion | 9 | 03-08-2008 07:02 PM |
| Cleaning The Buttons on Comand Nav? | joelreznick | Caring for your SLK | 0 | 08-16-2007 03:57 PM |
| Can the 7g buttons be changed for paddles? | aquascape | SLK R171 General Discussion | 25 | 06-18-2007 10:14 AM |
| What is the latest euro Comand Nav DVD version? | mcat | SLK R171 General Discussion | 19 | 08-03-2006 11:18 PM |
