Go Back   Mercedes SLK World Forum > General Discussion about Mercedes Benz SLK's > Caring for your SLK
Caring for your SLK Detailing and Car Care Tips
Windrestrictor
Old 04-15-2007   #1 (permalink)
Vehicle: SLK 230 1998
Default T-Cut or Not T-Cut?
Taking advantage of the excellent weather today, I spent rather a long time cleaning my car inside and out.
On the Boot Panel, there is two very small spots of discolouration/corrosion? where two seperate lot of Bird Droppings have been. I usually wash these off as soon as I notice them, but have a been away a couple of days and didn't have chance.
Anyways.... Is it worth t-cutting the panel to correct? or is it more worth my while taking it to a proper paint/repair garage?
View Elwood's Photo Album Elwood is offline
Old 04-15-2007   #2 (permalink)
DesignoSLK's Avatar
Vehicle: 2000 Designo SLK230
Donation Level 3
What is "t-cutting"?
Kevin
An American in Germany...
Old 04-15-2007   #3 (permalink)
"T-Cut helps to easily remove surface oxidation, blemishes and mild scratches easily restoring the lustrous colour of your car in minutes."..
It's basically a coloured polish. It gets good reviews but i've never used it myself.
If I decide to t-cut i'll do some before and after pics and write a brief review.
Old 04-15-2007   #4 (permalink)
http://www.carplancarcare.co.uk/index.cfm?category=58
Old 04-15-2007   #5 (permalink)
Founding Member #8
Vehicle: 2004 SLK350
Be very careful with T-cut - it is actually akin to 'grinding paste' - it removes the top layer of paint (or clear coat lacquer). It gives good results, but extended use will result in bare shiny metal.. If you do want to try it, use T-Cut for metallic paint - it is slightly less harsh, and don't make a habit of using it.
1999 Ducati ST2
2003 Vauxhaul Vectra
1974 Triumph Bonneville 750
T140V
1937 Norton 500 single
(all still current)
Old 04-15-2007   #6 (permalink)
Cheers Wooly.
Only intend using it once just to get rid of the little inperfection, but thanks for the advice. Will save future over-use - I'll use sparingly.
Think i'll opt for the T-Cut colour fast metallic. Will try on a discreet panel first to see what the results are like prior to doing the boot panel.
Old 04-15-2007   #7 (permalink)
DesignoSLK's Avatar
Donation Level 3
What's the effective difference b/w T-Cut and claying?
Kevin
Old 04-15-2007   #8 (permalink)
Unsure about claying. From what i've read on other posts this removes the layer of wax etc.. prior to doing a deep polish.
I think T-cut is more of a scratch/oxidisation fixer, bringing out the next layer of paint to cover up inperfections.
Old 04-15-2007   #9 (permalink)
Vehicle: SLK55 2006
i don't know how it compares, but Meguirs ScratchX works really well for things like you are describing. Very Mild, yet works wonders. I use 3m extra fine rubbing compound for more serious things, but also removes paint.
Old 04-16-2007   #10 (permalink)
alroumi's Avatar
I have a Scottish friend that recomended the T-cut he keeps using it on his Xtype, I will just warn him that it could possibly remove the paint and the clearcoat with excessive use.
Thank you guys.
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
Old 04-16-2007   #11 (permalink)
N4PWJ's Avatar
Vehicle: 2006,slk280,carlsson
Other Toys: Caterham
T-Cut is very good, but over use does wear away the paint.
For this slight fade of colour due to bird crap, i would use the scratch X by Meguiars, as it is far less harsh than T-Cut and works well on this type of thing. Just make sure after you have used it to give the area a good wax and polish, to protect the paint again. I wuold recommend superguard or lifeshine after this type of procedure.
Old 04-16-2007   #12 (permalink)
Founding Member #3
mcat's Avatar
T-Cut will remove a layer of clearcoat and paint. Try Claying before resorting to this..
The following may help ....
http://www.howtocleananything.com/ti...s.asp?tid=1243
As soon as you have cleaned it get a layer of Zaino on to protect for the future.
View mcat's Photo Album mcat is offline
Cut Steering Wheel...???? SLKman Performance MODS for the R170 8 10-14-2008 04:06 PM
engine cut out kit 210 SLK R170 General Discussion 8 01-09-2007 07:44 AM
