Vehicle: 2006,slk280,carlsson
Country: Thanks: 1
| I have considered upgrading my brakes to the slk350 vented discs at front.(mine is an SLK280) will they be a direct swap? or will i need new calipers,carriers etc etc? |
Country: Thanks: 135
| It should be a direct swap, but you might want to change the calipers as well, they look much better than the ones on the SLK280, the only problem I see is it might not cleared the 16" wheels but since you have aftermarket 19"s, that should not be a problem. DanSLK should be able to give you a better answer.
Country: Thanks: 1
| looking at that pic there ynot i realise the calipers are 4 pot, not suer what the 280's are but i think it would def be worth it. much nicer looking and obvioulsy work better. |
Country: Thanks: 96
| Hi, As Ynot says prob a caliper change is probably a good idea here. Apart from that i really don't see any difficulty here mate it should be a direct swap for you. Hope this helps and any more questions just ask. Dan
Vehicle: ///AMG
Country: Thanks: 17
__________________ "I'm not a roman mum, I'm a kike, a yid, a heebie, a hook-nose, I'm kosher mum, I'm a Red Sea pedestrian, and proud of it!" Life of Brian To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Last edited by easty; 10-11-2006 at 10:01 AM. |
| | #6 (permalink) | |
280: Brakes Dual-circuit power-assisted 4-wheel disc brakes. 11.8" ventilated front discs and 10.9" solid rear discs. Single-piston floating front and dual-piston fixed rear calipers. 350: Brakes Dual-circuit power-assisted 4-wheel disc brakes. 13.0" perforated and ventilated front discs and 11.4" solid rear discs. Dual-piston fixed front and dual-piston fixed rear calipers. 55: Brakes AMG-enhanced dual-circuit power-assisted 4-wheel disc brakes. 13.4" perforated and ventilated front discs and 13.0" ventilated rear discs. AMG 6-piston fixed front and AMG 4-piston fixed rear calipers. Easty, those AMG brakes looks huge.
__________________ 06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Last edited by Ynot; 10-12-2006 at 12:07 AM. | |
Country: Thanks: 1
| DROOL!!!!!!!!!! i want those AMG brakes,but are very pricey unfortunately. If i had moer free cash i would definately buy them. Thanks for the help guys , think im going to go searching for a written off 350 or 55AMG in Europe.great website for finding prts in uk is www.findapart.com for anyone who is interested. |
| Brakes upgrade or not ??? | Prado | Ask DansSLK | 3 | 09-05-2008 10:47 AM |
| brakes | dsuanthie | SLK R170 General Discussion | 2 | 09-04-2008 11:09 PM |
| SLK55 Brakes | nickoloff | SLK R171 General Discussion | 5 | 09-03-2008 09:44 AM |
| Brakes | Dennis | SLK R171 General Discussion | 7 | 05-10-2008 03:43 PM |
| Changing brakes? | dsb | Ask DansSLK | 5 | 10-22-2006 09:56 AM |
