Windrestrictor
Old 09-05-2008   #1 (permalink)
Default BAS ESP captio
Hi Dan,
Being as I've posted this question in the R170 forum with numerous views and nil reponse (again) I thought you may be able to help?
In the abscence of a manual can anyone shed any light as to a permanent "BAS ESP" caption illuminated at all times on my R170?
Thanks in Anticipation.
View mun802's Photo Album mun802 is offline
Old 09-06-2008   #2 (permalink)
Brake light switch perhaps?
Old 09-07-2008   #3 (permalink)
Gabus's Avatar
Vehicle: 96 SLK 230K
Other Toys: Volvo L3314N
If it is the brake switch, the light should not go on before you hit the brake for the first time after you started the engine.
If the voltage on the battery is to low the light will be on.
If your esp needs a calibration the light will be on.
How to calibrate:
Start engine. Turn wheel full left, and then full right. If that was the problem the light will go off. (That is a must after battery been disconnected.)
If the circuit of the wheels differs to much the light will go on.
There is also a transmitter placed in the center console that can be broken.
A trip to a dealer and get a diagnose can be useful.....
Gabus
HELP! ABS/BAS/ESP warning lights on and top problem ||SLK320|| SLK R170 General Discussion 3 09-16-2008 07:18 AM
BAS ESP Caption mun802 SLK R170 General Discussion 3 09-05-2008 12:10 PM
In intro and that perpetual old chestnut - BAS ESP light on... shonaslk Help and Support 10 08-03-2008 03:15 AM
Break Light Fuse/BAS ESP wangjen Help and Support 5 07-20-2008 04:52 PM
ESP Defective, BAS Defective fleep SLK R171 General Discussion 10 06-05-2008 10:39 AM
