| SLK World Junior Member Join Date: Aug 2008
| I've been having occasional problems withe the indicators and hazrds not flashing, remaining on. Problem kept rectifying itself but its getting worse. I suspect the indicator relay, does anyone know where it is Thanks Guido |
Country: Thanks: 96
| Should have a fuse map with it mate, it will contain the info you need. Normally in the primary fuse box.
| | #5 (permalink) | |
Country: Thanks: 2
I located this forum by googling for this same problem. Did you ever find the location of the flasher unit? I don't know what source of info the earlier reply referred to - I did :rtfm: but the manual is f all use! And a big reference diagram the garage has not much better - seemed to locate it in huge box of electrics at back right of engine compartment vieweed from front of ocar - but where if in there? I fear it may be sone electronic flash which will bankrupt me! HELP ANYONE! | |
| Elite SLK World Member Join Date: May 2007 Location: Søgne
Vehicle: 96 SLK 230K
Country: Thanks: 17
| It should be in this box: ![]() On this board:
| The Following 2 Users Say Thank You to Gabus For This Useful Post: |
Country: Thanks: 2
| Thanks Gabus - that should be a great help. I presume it is the "bliknrelais" I want - and can guess what that means. Do I need to know what the other thing in red is? ???triefen? Interestingly, my RHD car has the battery and that box on the other side - presumeably to be near steering wheel. Steve |
| | #9 (permalink) |
Country: Thanks: 17
| There should be contact between the output on the relay and the "metal strips"
| The Following User Says Thank You to Gabus For This Useful Post: |
| Door lock LED flashing? | jfb1977 | General Discussion | 4 | 10-07-2008 06:46 AM |
| Flashing alarm LED | arosamond | SLK R171 General Discussion | 4 | 09-26-2008 01:32 PM |
| Flashing Brakelights! | Borderwave2 | General Discussion | 3 | 04-19-2007 12:40 AM |
| NoRegret4Life's KLEYMAN Flashing 3rd Brake Light Module | SLKman | SLK R170 General Discussion | 28 | 11-13-2006 10:49 AM |
| 3rd Light Flashing Module | SLKman | Ask DansSLK | 3 | 09-27-2006 01:01 PM |
