Windrestrictor
Old 09-12-2006   #1 (permalink)
Vehicle: '05 SLK350
Default R170 3rd Brake light (Kleyman 1 install)
Hey Dan.
SLKman will be installing the Kleyman 1 module on his R170.
I'm pretty sure all the connections will be the same, however just want to make sure.
Do you think you can provide some feedback on removing the pannel from the trunk lid and perhaps the harness connection of the 3rd brake light?
Thanks.
Old 09-12-2006   #2 (permalink)
Sure the cover should be held on by the same push pin type setup that is on the 171 so no differences there.
The lamp unit gets it power from the light module via a black and blue wire arriving at pin 1 on the lamp the power then exits the lamp via pin 3 and goes on to the right license plate lamp.
Hope this helps
Dan
AMG smoked rear light clusters / 3rd brake light. jfb1977 Where to get R171 SLK Items 2 07-24-2008 11:40 AM
3rd brake light flasher st2288 General Modifications R171 21 05-23-2008 10:11 AM
3rd Brake light flasher noregret4life General Modifications R170 30 12-21-2007 11:22 AM
NoRegret4Life's KLEYMAN Flashing 3rd Brake Light Module SLKman SLK R170 General Discussion 28 11-13-2006 10:49 AM
Received my Kleyman1 3rd brake light module -1- SLK R171 General Discussion 51 10-13-2006 06:22 AM
