Windrestrictor
Old 05-31-2008   #1 (permalink)
Silver Supporter
cbelaney's Avatar
Vehicle: Handmade SLK 350
Other Toys: 1970 Cadillac Deville conv.
Default smartkey not functioning
Dan, I have almost everything working correctly...350 ECU, 280 Trans valve body/module, 280 cluster and ignition. Runs, shifts, and drives perfectly. My last problem(crossing fingers) is the fact that my smartkey does not work. Any ideas on where to start diagnosing what might be wrong. The batteries are good. At this point I would be curious if there is some way to open the fuel door without the smartkey working? The smartkey worked when everything was a 280....Thanks.
View cbelaney's Photo Album cbelaney is offline
Old 06-01-2008   #2 (permalink)
Thats a weird one, it starts using the key right?
Old 06-01-2008   #3 (permalink)
Silver Supporter
cbelaney's Avatar
sorry to bother...I fixed it this morning. The bodyshop had broken the antenna connection...easy fix. They probably unscrewed the antenna before disconnecting it to paint. Thanks.
Old 06-01-2008   #4 (permalink)
Was gonna sugest the signal was at fault, glad you've sussed it.
New Smartkey upgrade BradSLK55(IN) General Modifications R171 3 06-27-2008 10:06 AM
