| SLK World Member Join Date: Jul 2007
Country: Thanks: 4
| Hi Dan; I recently purchased a Sirius Radio but unfortunately the built in FM modulator is just terrible since the FCC in the States changed the allowable output of these units. I have an older XM whose car kit modulator is so much stronger as it was produced prior to the FCC changes. I would like to install a FM modulator directly through the antenna for my Sirius radio and was wondering if you could confirm that these are the correct adapter for my A20 head unit. Thanks as usual for your help. http://www.myradiostore.com/sirius/s...s-40-eu30.html |
Country: Thanks: 4
| Dan I plan to use it with one of the following FM Modulators and would also welcome your recommendation as to which FM modulator you recommend. Thanks in advance; JC http://www.myradiostore.com/sirius/s...4-fmmod02.html or http://www.myradiostore.com/sirius/s...ifmmore14.html |
| Bluetooth Adapter | RedDevil07 | Help and Support | 3 | 06-12-2008 07:03 PM |
| removing the sirius antenna | linuxpro | General Discussion | 2 | 06-09-2008 07:54 PM |
| Sirius Antenna Trunk Wart | Tummy | SLK R171 General Discussion | 21 | 03-25-2008 09:53 AM |
| Sirius Antenna Cable Routing | bildio | SLK R171 General Discussion | 3 | 11-04-2007 05:14 PM |
| Sencond generation bluetooth adapter? | Charlie | SLK R171 General Discussion | 6 | 05-08-2007 08:39 PM |
