Welcome to SLKWorld
Old 05-22-2008   #1 (permalink)
SLK World Junior Member
Vehicle: 1999 slk 230 K
Other Toys: 2001 Dodge ram sport 4x4 (lifted, worked), 2007 Harley Davidson 1200 Nightster
Default DanSLK need help, 1999 SLK 230 K Headaches!!!
Dan,
I am a new guy here, I just purchased a 1999 SLK 230 K about 8 months ago about 40k miles on it.
To give you a run down I replaced the PSE about 2 months ago, because I found major corrosion on it and the alarm was going nuts all the time. Once I installed the new PSE, everything worked fine again, but the alarm horn would go off constantly, so I pulled the #9 fuse, to get the horn to stop temporary.
Now here are the other issues I have:
1. My doors won't lock or unlock using the remote, but they will unlock and lock when I use the switch under the radio in the car.
2. The Anti-tow switch light stays on all the time now.
3. The fog lights and rear running lights flicker (come on and go off)occasionally(while the car is sitting in the driveway), and while they flicker and come on I hear a small noise from the headlight switch to the left of the steering wheel.
Any help would be much appreciated,,,,
Thanks!!
View jcbransome's Photo Album jcbransome is offline
1999 Red SLK 230K - 7,825 miles steveinlanc SLK R170 General Discussion 9 08-26-2008 04:09 PM
01 280 SLK bumper fit a 01 230 Slk? ziagroup SLK R170 General Discussion 4 07-25-2008 05:14 PM
slk 230 Kompressor 1999 (im new!) dzia7799 Help and Support 2 03-12-2008 11:46 AM
1999 Slk 230 Gilroy SLK R170 General Discussion 2 02-27-2008 06:36 AM
water leaks 1999 slk 230 carl General Discussion 0 01-21-2008 04:10 PM
