Old 10-08-2007   #1 (permalink)
Other Toys: Too many!
Send a message via AIM to igosuperfast Send a message via MSN to igosuperfast
Default Subwoofer Blown
Hi there,
My battery died on me as I was starting the car (2001 SLK320) and I think it blew my subwoofers out. How do I know if it's the fuse or the actual amp?
Thanks alot
View igosuperfast's Photo Album igosuperfast is offline
Old 10-08-2007   #2 (permalink)
So you have no sound at the moment then?
Old 10-09-2007   #3 (permalink)
I have sound in the other speakers, just not the two bose speakers in the back, not even static. I tried to look for the fuses in the fuse box and the aux. fuse box but none of the fuses were for speakers. Do I have to remove the back molding under the trunk?
Old 10-09-2007   #4 (permalink)
The two speakers located at the top of the vertical rear bulkhead storage unit gives minimal/barely noticeable sound. Tslick has suggested to cover the openings with aluminum, and then without, with the music on to see if you'll notice a difference. If there is, then the two small rear speakers are working.
Old 10-09-2007   #5 (permalink)
Vehicle: SLK55 2006
I beleive the R170s had fewer rear speakers, but were more noticable (not having the 7 channel sound system).
Old 10-09-2007   #6 (permalink)
Founding Member #7
mtiede's Avatar
IIRC, the Bose bass speaker was behind the driver's seat. They didn't have the little speakers above the center console. Different arrangement entirely.
Old 10-09-2007   #7 (permalink)
OK so with your cars MY the Bose system takes a feed from the radio and sends it to the amp via a discreet set of lines, the amp then drives the speakers.
If you have lost 2 speakers you need to start with them and work back to the amp then the radio itself.
Clearly its not a fuse issue so you need to check the rear speakers are getting power if they are then they are defective and should be replaced.
If they are not getting power check the outputs on the amp if its not providing power on the speaker outputs check its getting signal inputs on all the feeds from the radio, if all the inputs are OK but some of the outputs are bad replace the amp, if all the inputs and outputs are OK you have a wiring problem.
If inputs to the amp are not all OK then check the outputs on the radio same as above applies if all good outputs then you have a wiring fault, if you do not have a full set of good outputs from the radio its defective and should be replaced.
Hope this helps.
Sorry for the delay since 170's are not my specialty i doubled checked the wiring diagrams.
Old 10-09-2007   #8 (permalink)
Thanksmuch DansSLK!
Old 11-09-2007   #9 (permalink)
Vehicle: '98 SLK230
Other Toys: '96 328IS
Send a message via Yahoo to SLKjay
Question
Originally Posted by igosuperfast View Post
Thanksmuch DansSLK!
any updates on your issue?
View SLKjay's Photo Album SLKjay is offline
my head has blown up.. 18" alloys for r171!! bjj007 General Modifications R171 5 1 Week Ago 07:50 AM
Are my tweeters blown? smoothbnzf4n4tc Ask DansSLK 14 10-12-2008 06:11 PM
SLK 320 subwoofer question ||SLK320|| SLK R170 General Discussion 10 06-16-2008 07:50 PM
SLKWorld 2006-2009
