| SLK World Member Join Date: Jun 2007 Location: South Africa
Vehicle: '06 350 SLK BLACK!!
| How do I remove the grille that houses the driving / fog light? I see a 12mm bolt and a (phillips type) screw. Must these be unscrewed? (I wanted to upload a pic but I dont know how - Quick upload doesnt lat me browse.) Is it so that the latest SLK's do not have the option of going into the Command system? I want to have video on the go and have tried the "hidden menu" info I got from this forum, but it does not work on my car! Pitty? Any other way? Regards W |
| Sponsored Links | |
Country: Thanks: 385
| IIRC, the procedure for getting into the engineering menu works only for European spec COMAND that are model year 2005 and maybe early 2006.
Country: Thanks: 99
| Ditto, Engineering mode has now been removed. Not sure i understand the fog light question sorry. To upload an image select post reply (don't use the quick reply feature) then pick on manage attachment's and you will see the needed options.
| I want to remove the grill of the driving light - pic. included. How? Regards. W |
| Sponsored Links | |
Vehicle: SLK 55 AMG
Country: Thanks: 6
| You have to remove the bottom engine compartment paneling at front. Then you can disconnect the connector (1), remove the screws (2) and it should be ok.
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ------Michel------ -SLK 55 AMG 2005- |
| Sponsored Links | |
| 2000 slk230 wind deflector and grille needed | kightboy | Where to get R171 SLK Items | 1 | 09-10-2008 01:39 AM |
| New grille | bonsaxen | General Modifications R170 | 15 | 04-15-2008 12:42 AM |
| They lifted the fog | Tslick | AMGs | 2 | 07-05-2007 09:00 AM |
| Grille Matt black or gloss | Mike Hampshire | SLK R171 General Discussion | 9 | 02-26-2007 11:38 AM |
| Grille Fins (Matt Black or Gloss ?) | Mike Hampshire | General Modifications R171 | 0 | 02-21-2007 07:30 AM |
