| SLK World Member Join Date: Apr 2007 Location: Tennessee
| Hi, I have an SLK 32 amg 2002 model. When coasting or driving at low speeds around 25 mph you can hear a roaring noise coming from the rear. At higher speeds its hard to hear over road noise. THe noise doesnt change with turning as to indicate a wheel bearing. Has anyone seen carrier bearings in the rear diff fail on these models? Im pretty sure its not a tire issue. I will have to get it on a lift to try and pinpoint but sounds like a bearing issue. Thanks for any info. |
| Sponsored Links | |
Country: Thanks: 99
| MB diffs are quite reliable is it coming from the middle section of the car. If you get it on a lift and run it up to speed should be easy to tell.
| The noise does seem to come from the middle of the car, rear of the seats. I have turned left and right to try and determine a wheel bearing but the noise didnt change. Also there isnt any gear whine. I will try to get it up soon and listen. |
Country: Thanks: 99
| Yeah thats best get it up on a lift will be easy to pinpoint
| Sponsored Links | |
| SLK idle pulley noise demo | Ikarus | SLK R171 General Discussion | 34 | 07-24-2008 10:45 PM |
| Problems with Right Rear Window 2005 SLK | jamesliu426 | General Discussion | 2 | 06-29-2008 03:03 PM |
| SLK rear fog light? | -1- | SLK R171 General Discussion | 48 | 05-23-2008 07:45 AM |
| SLK noise when parked :-/ | micktick | SLK R171 General Discussion | 16 | 02-05-2008 07:03 PM |
| 01 Slk 320 Door Hinge Noise - Now What? | kcbimmer71 | General Discussion | 7 | 08-10-2006 07:05 AM |
