Old 05-28-2007   #1 (permalink)
Default Flasher Relay in R171
Dan,
what type of flasher relay is used in R171? Is it a thermal relay or electronic relay? I'm going to replace turn signal bulbs to LED bulbs and I don't want to put load resister because it produces very high heat. I found electronic flasher relay in eBay, which covers 12 V 0.02-20A, so it doesn't need load resister. Is there any other circuits involved to R171's flasher relay such as bulb failure monitoring circuit, etc. I will try electronic relay, but I'm little but scared about possibility to damage to my car. And where is the flasher relay in R171?
Here is the link to electronic relay in eBay: http://cgi.ebay.com/ebaymotors/3-PIN...spagenameZWDVW
View zxxn's Photo Album zxxn is offline
Old 05-28-2007   #2 (permalink)
It does not have a relay to control them the front and rear lights use the nearest SAM to provide the pulsed power and the side repeaters use the respective door control modules.
100% solid state electronic sorry mate, its used because its more efficient much less complicated and lighter than a relay controlled system.
Old 05-28-2007   #3 (permalink)
Thanks for info. Then I should use load resistor.
How the ticking sound produced when I turn on signal light?
Is there a speaker for it?
Old 05-28-2007   #4 (permalink)
Put your ear to the right hand side of the instrument cluster and have a listen.
It uses the in-built beeper to provide the feedback same one that gives you the warning beeps.
Old 05-28-2007   #5 (permalink)
I see..... Thanks!
K40 relay module bazzle SLK R170 General Discussion 21 6 Days Ago 07:15 AM
Brake Light Flasher noregret4life General Modifications R171 191 1 Week Ago 10:55 AM
3rd brake light flasher st2288 General Modifications R171 21 05-23-2008 10:11 AM
3rd Brake light flasher noregret4life General Modifications R170 30 12-21-2007 11:22 AM
Fitted the brake light flasher PAPA General Modifications R170 21 11-21-2006 03:47 AM
SLKWorld 2006-2009
