| Senior SLK World Member Join Date: Oct 2006 Location: Paris, London, Cannes, Jeddah, Dubai
Vehicle: SLK55 AMG
Country: Thanks: 23
| Hi Dan, my nav is going crazy when i look at the map it shows me that im in a different place than where im actually in. i tried removing the dvd and placed it back but still its going coo coo. then when i got home i reset the command i still didnt show the right location till 1 min later. should i take the car to mb? or is there another way to reset the nav and fix it? thank you in advance. Regards, M. Jawa
__________________ M. Jawa 2006 SLK55 AMG |
| Sponsored Links | |
Country: Thanks: 99
| Hey mate, What you wanna do is park the car up undercover if possible but if you cant then outside will do then shut everything down and open the bonnet. Remove the nav DVD from the boot and close the lid then wait 3 minutes and disconnect the battery for about an hour. When the time is up hook it back up again get in the car and go to position 2 on the key set the COMAND to nav then when it asks insert the DVD it should boot back up and now all should be well. If this does not work there is another option before needing to get the codes read i will post that up if this trick does not work. Just remember to lower the drivers window before you take the key out otherwise if you need to get into the car while the battery is off you could damage the seals
| Banned Join Date: Jan 2007
| I´m not sure Dan, but if you disconnect the battery, shouldn´t you teach the ESP and the windows after the reconnection? Full open and close the windows and turn the steeringwheel from max. left to max. right? |
Vehicle: SLK55 AMG
Country: Thanks: 23
| thanx for the help Dan ill try it tonight and post the results. regards, M. Jawa
| Sponsored Links | |
| Senior SLK World Member Join Date: Jul 2006 Location: Newbury, UK
Vehicle: SLK55 AMG
| The instructions with new Nav discs don't say anything about disconnecting the battery. However, they do describe a procedure which causes COMAND to initialise itself (steps 3-7 below). So you could try:
Country: Thanks: 99
| OK gotta clear a few things up. Gero, well done mate i forgot about that MJawa 55 you will need to re-initialize the windows after reconnecting the battery by pressing and holding the switches for the windows on the drivers side in the second (auto-up) detent for about 5 seconds after the windows close, the ESP will sort itself out its the older models that require the steering angle sensor to be calibrated. Steve, Thats the procedure for loading new nav software you can do the same by removing the old disk and inserting the new one with COMAND switched on and it will load automatically not sure why they give such a drawn out procedure its not needed, the COMAND will remember its location using that method you need to disconnect the battery to erase it. As far as i am aware the head unit cannot be aligned using SDS so the procedure would be the same. Pulling the battery is also good for clearing the ECU and TCU adaption values should your car enter granny mode.
Vehicle: SLK55 AMG
Country: Thanks: 23
| the nav just seemed to fix its self, when i started the car up last night it was a bit on the crazy side then it was fine and working well and its still working. didn't have to do a thing but thank you guys for all the help. Regards, M. Jawa
| | #9 (permalink) |
Vehicle: SLK55 AMG
Country: Thanks: 23
| no, it actually went crazy after it was delivered from service B. I just disconected the batteries 15 min ago in order to reset the nav bc it was still going haywire
| OK, this guy's REALLY confused! | SLKCop | Mercedes Benz Posers | 24 | 10-31-2008 06:08 AM |
| NAV Upgrade.... | RacerCub68 | Ask DansSLK | 12 | 09-28-2007 07:45 PM |
| Sat Nav | Nita | General Modifications R171 | 6 | 04-20-2007 09:03 AM |
| nav question | V8SLK | Ask DansSLK | 1 | 09-09-2006 01:23 PM |
