Vehicle: SLK55 2006
Country: Thanks: 26
| Hey Dan, need some help here, i want to completely disassemble the headlight assembly, any schematics, or instructions will help! thanks in advance! |
| Sponsored Links | |
Country: Thanks: 96
| Is there any rush for this mate? We don't have procedures for a full disassembly i will have to work something out with a tech about how to do it on Monday. Sorry
Vehicle: SLK55 2006
Country: Thanks: 26
| wow dan! thanks! it's 7AM over there and you are already at work? anyway, thanks a lot dan, hopefully sometime before tuesday? i've got some plans... |
Country: Thanks: 96
| Hi Edward, Was chatting with one of the guys today and mentioned this to him and i while i will check with the others Monday its not looking too good. Thing is MB call it sealed but from experience both me and him know this not to be true (we have seen them fall apart many a time) only thing is we don't know how its supposed to come apart because we have never actually had t do this and since MB call it sealed they don't publish procedures. I would imagine its a case of stripping all the bulbs out and removing the plastic from the back case but i cant say for sure how this is done. Will post up again Monday after asking the others.
| SLK World Member Join Date: Nov 2006 Location: London
Vehicle: SLK 350
| Hi there On the subject of lighting, my nearside (nonAMG) fog light lense is cracked, doesn't look like something hit it, but it would be difficult to prove that it is a faulty assembly. Might have cracked using it a lot in the fog before Xmas. How easy do you think it would be to replace myself ? Many thanks |
| | #8 (permalink) | |
Vehicle: ///AMG
Country: Thanks: 18
The reason I know is that I wanted a replacement fog and they tried to sell me a NON-AMG cover. the AMG fogs dont have a cover and the whole light needs replacing at about $180. ;(
__________________ "I'm not a roman mum, I'm a kike, a yid, a heebie, a hook-nose, I'm kosher mum, I'm a Red Sea pedestrian, and proud of it!" Life of Brian To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. | |
| | #9 (permalink) | |
Country: Thanks: 96
Edward, Not really sure how to take the unit itself apart mate sorry its not something we have done ourselves before but as i say they do come apart so a little exploration might be needed. Sorry about that mate.
| | #11 (permalink) |
Vehicle: SLK 350
| right then... bought the lense... 10 quid. Had a look at the fog light, I can't work out how to get at it, do I approach it from the front by removing the small black grill? I can only find one screw which I think adjusts the angle. There is a conical piece of plastic which pokes thro a hole and that will snap inwards, but other than that I am lost. Any ideas .... thanks alot in advance. |
| | #12 (permalink) |
Country: Thanks: 96
| It should just be clipped on mate you should be able to see the 3 clamps in front of the cover.
| | #13 (permalink) | |
Vehicle: SLK 350
Guess I will have to give up and go to the dealers... Thanks for all your help | |
| | #14 (permalink) |
Country: Thanks: 384
| How about checking from behind the fog lamp mount? Turn the front wheels towards the opposite side, remove 2 silver bolts from the bottom (holds the rubber wheel well cover to the flat bottom plastic) and two black bolts at the wheel well. Flex the rubber wheel well cover and see what it looks like from behind. (same procedure as changing the front fender lamps for US models)
| | #15 (permalink) |
Vehicle: SLK55 2006
Country: Thanks: 26
| hey guys, back to the origin of this thread, the headlight comes out of the car via several bolts from the back the headlight (hard to reach). the clear peice in front has several clips that you can just pry off. the next step is a bitch, apparently, it has some sort of sealant all around the edge of the light. i'm gonna try a heat gun and see if it'll come apart. |
| | #16 (permalink) | |
Country: Thanks: 96
The clips should be visible but maybe the alignment of the grill is blocking them or something
| | #17 (permalink) | |
Country: Thanks: 96
| | #18 (permalink) | |
Vehicle: SLK 350
Thanks for you help guys. | |
| | #19 (permalink) | |
Country: Thanks: 96
| | #20 (permalink) | |
