ESP BAS speedtronic malfunction - Mercedes Benz SLK World Forum
Go Back   Mercedes Benz SLK World Forum > Technical Information > Ask DansSLK
Ask DansSLK Ask your technical questions to DansSLK - certified MB technician
SLKWorld.com is the premier Mercedes-Benz SLK Forum on the internet. Registered Users do not see the above ads.
Old 06-18-2010   #1 (permalink)
vvk
Vehicle: 2005 SLK350 6-speed
Question ESP BAS speedtronic malfunction
2005 SLK 350 6-speed 24k miles
Whenever I start the car, I immediately get 2 warnings:
-- ESP malfunction visit workshop
-- BAS malfunction visit workshop
When I try to use cruise control I get a message about speedtronic malfunction.
Right before I started getting these warnings, there was a weird thing that happened with my window. It started raining so I closed the roof. I opened the windows and then closed them while accelerating. Driver side window closed normally but passenger side stopped half way and I am pretty sure I heard a beep from the car when this happened. I had to press the window switch again and the window closed. I have a suspicion that the battery voltage dropped when the window failed to close. As soon as that happened, I noticed the ESP/BAS malfunction warning.
ESP seems to be working as always. That is, the car seems to correct for oversteer and the yellow triangle flashes as usual.
Other than the messages and cruise control not working, I detect nothing wrong.
I have tried calibrating my steering angle sensor by turning wheels all the way to the left and then all the way to the right.
After having read about this problem on the Net, today I removed the plastic panel below the steering wheel to see if I can take a look at the brake light switch.
There is a plastic shroud that prevents me from getting access to clutch and brake pedals. I tried to remove it but could not. I did not want to break it, so I was not very forceful. Can anyone tell me how to remove this plastic shroud?
I have done this on several other cars that needed brake pedal adjusted or brake light switch fixed or replaced. However, for the life of me I am not able to figure out where the brake light switch is on my R171.
I can see the clutch switch.
There was also another switch that sits on top of the plastic shroud. I was not able to feel its plunger from inside the plastic shroud with my finger. I am not sure what the switch is. It is part #0045452114. I was able to remove it by rotating. I tried pressing on the plunger to check if the brake lights will turn on. They did not turn on. When I pressed on the brake pedal with this switch removed the lights did turn on. I tested this switch with an ohmmeter and it does seem to respond when I press the plunger. Open with the plunger out and closed with the plunger depressed.
I could not locate any other switch on the brake pedal. I am beginning to suspect that it may be inside the brake booster on the other side of the firewall.
Does anyone know where the "other" brake light switch is located? The one that turns on the stop lights?
Thanks!
View vvk's Photo Album vvk is offline
Old 06-18-2010   #2 (permalink)
aka John
Vehicle: RHD Jasper Blue C200K Coupe, RHD Jasper Blue SLK55, LHD Black SLK350, LHD Firemist SLK55
Chats: 1143
Honestly, the easiest thing to do would be to read the codes on the car and see what's causing the errors. Brake lights are controlled by the rear SAM, and are triggered by a CAN-C signal if my memory serves (I'm on the road, with no access to WIS...).
There are *very* few physical switches in the R171 that do anything other than generate a CAN signal, so unless you have a physical failure of a switch, it's easier to ask the car what it thinks is wrong and work from there.
My dodgy Bogota hotel intertubes also time out trying to connect to TIPS or EPC, so I'm having to work from memory! Luckily, I'm headed back towards London at the arse crack of dawn tomorrow, so I'll see what I can dig up Sunday afternoon when I get home!
Life is good - enjoy it with the top down!
Old 06-18-2010   #3 (permalink)
vvk
Question Read codes
UK-C200, Thanks so much for your quick reply.
In fact, I was thinking along the same lines and began by searching for a way to read the trouble codes. However, unlike VAGCOM, BMW GT1 and other systems I am familiar with, I have not been able to find anything remotely affordable for a shadetree mechanic. The best I have been able to find so far is some Taiwanese set for $5800 on eBay.
I forgot to mention that I get solid 12.5 V with the engine off and 14.5V with it on.
Old 06-19-2010   #4 (permalink)
Passionate SLK World Member
Vehicle: 05 55 (Brabus 6.1 S)
Chats: 28
OK so the switch you had out is the clutch switch, the brake lights are triggered by a sensor inside the booster that measures diaphram travel, the signal travels as John says (Sensor>ESP CM>CAN-C>CGW>CAN-B>R SAM>LED).
It sounds like either an internal control unit fault or a failure in BAS to me, as John rightly says, your best bet is to find out what the car thinks is wrong and then determine what *is* wrong based on that, dealer shouldn't charge more than one unit for the diagnosis and then you can handle the fix yourself.
Spending money on the kit is a huge investment unless you plan on staying with Benz for a VERRRRY long time!
Old 06-19-2010   #5 (permalink)
Chats: 28
OH while i think about it, why dont you go to the Startekinfo site that MBUSA maintain and look into the passthrough system that they are legally required to offer, that will be cheaper/less functional than proper DAS but will allow you to read all codes.
Old 06-19-2010   #6 (permalink)
vvk
Question Thanks!
DansSlk,
Thanks so much, I really appreciate your tips! I can stop looking for the brake light switch now :-)
I guess I will have to get professional help with this. I just like to have all my bases covered before doing that.
Another quick question for you. Does this car require ABS pump to be in brake flush mode in order to flush brake fluid like BMWs do? Thanks!
Old 06-19-2010   #7 (permalink)
Chats: 28
Not for a fluid change it doesn't no.
Old 04-08-2011   #8 (permalink)
vvk
Just wanted to give a quick update. I picked my car up from the dealer yesterday. They said I need a new brake booster. Their price quote was $1350.
Needless to say, I am going to repair this myself.
ABS & ESP malfunction not fixed by dealer gd197 SLK R171 General Discussion 23 04-12-2012 01:51 AM
ESP Malfunction & ABS Malfunction pnsji Ask DansSLK 11 10-27-2010 07:06 PM
ESP Defective, BAS Defective fleep SLK R171 General Discussion 12 04-20-2010 06:12 PM
Bas esp abs wscroggin Ask DansSLK 11 07-13-2009 06:07 PM
Speedtronic to limit valet drivers speed? nmslk General Discussion 9 01-03-2008 07:27 PM
Powered by vBulletin Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226
