| Professional TV Watcher Join Date: Sep 2006 Location: Kaiserslautern, Germany
Vehicle: 2000 Designo SLK230
Country: Thanks: 104
| Hey Dan! I've noticed a vibration pretty much through out the car from 2000 to about 2300 rpms. Its sensed more at a stand still. I drove a '98 SLK230 and it was a little more noticeable around 2500 rpms. Is this indicative of the model/engine? It's definitely engine originated. It's not extremely annoying, but if there's something I can do about it, I'd like to.
__________________ Kevin An American in Germany... To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. '00 SLK230 Designo copper, '06 Saturn Vue, Cessna 172 (pilot) |
| Sponsored Links | |
Country: Thanks: 99
| Hi mate, I have felt the same thing in one or two R170's but have never pin pointed it has it started just recently?
Country: Thanks: 99
| It could be yeah there's loads of things that could have the effect its just hard to pin point
| Sponsored Links | |
| | #5 (permalink) | |
| Founding Member Join Date: Jun 2006 Location: Buizingen - Belgium
Vehicle: '05 SLK 350 - 7G
My main suspect would be the heat shield (next to the exhaust manifold).... | |
| I feel it at different speeds (mph), but always in the 2000-2300 range. Beyond that it's not there. I thought it might be tire related because before replacing them, it was a lot worse. But because the vibration was so bad before replacing the tires, once I replaced them, it was almost unnoticeable until this other guy pointed it out on his. (Nice run-on, huh?)
| | #8 (permalink) |
Country: Thanks: 99
| Well it does not have to be the innards of the engine to cause the noise it could be a pump or a belt causing the noise or any one of the components around the e-bay. The thing with the tires is that if these provide a better ride then the vibration's needed to start this off / allow it to vibrate more could be reduced so the noise gets harder to spot. Could be a heat shield but i would expect that to be related more to the road the car is driving on and temperature once the bay warms up the shield will tend to be jammed into place. This is going to sound silly but have you tested this at idle with the hood open and having a listen around and where does it actually come from? Could be the V-Belt could be the differential so if you could tell me where the noise is from that would help loads mate i don't wanna give advice based on what i have heard on other cars in case its a different noise so clarification would ease my mind a little that we are on the same page.
| | #9 (permalink) | |
Or maybe it's just me? ...nawaaaah
__________________ Kevin An American in Germany... To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. '00 SLK230 Designo copper, '06 Saturn Vue, Cessna 172 (pilot) | |
| | #10 (permalink) |
Country: Thanks: 99
| If you could try that would be great mate thanks. Hopefully it will be possible to narrow it down to a corner of the bay or something.
| Sponsored Links | |
| R170 fun | Tslick | SLK Videos | 16 | 09-29-2008 05:41 AM |
| Grinding/Vibration noise when FULL power | Otsego | Ask DansSLK | 7 | 08-04-2008 01:41 AM |
| 98 SLK230 Vibration | AJExtreme | SLK R170 General Discussion | 4 | 05-30-2008 09:51 PM |
| Steering Wheel Vibration | ellimb | SLK R171 General Discussion | 6 | 01-22-2008 07:11 PM |
| RPM fluctuating | kambakht | Ask DansSLK | 2 | 10-07-2007 03:29 PM |
