Old 11-06-2006   #1 (permalink)
Senior SLK World Member
MJawa 55's Avatar
Vehicle: SLK55 AMG
Exclamation garage door opener setup
Dear Dan,
I was wondering how to setup the garage door opener in my car? i went to MB west hampsted and they told me that i had to contact the company that installed the remote garage in my building and when i contacted them they said that they dont do that kind of thing and that MB should program it for me. now everyone keeps on saying its not us so i need your help if you dont mind since your the expert. Thank you.
Regards,
M.Jawa
M. Jawa
2006 SLK55 AMG
View MJawa 55's Photo Album MJawa 55 is offline
Old 11-06-2006   #2 (permalink)
OK first off erase it so its got a clean memory so press and hold the outer 2 buttons for longer than 20s the light on the unit should flash rapidly for about 10s once it is erased.
Then programming it pick what button you want to use and then press and hold it for longer than 20s then quickly aim the current transmitter for your door at the front of the unit thats looking towards it from the front of the car and activate it for about 2/3 minutes then once thats done you will either have a rapid flashing light on the GDO or nothing at all so then activate the unit by pressing the button you have just programmed and your door should operate.
There are restrictions on what models it can work but in general any homelink compatible door should work OK with the car.
Hope this helps
Dan
Old 11-06-2006   #3 (permalink)
MJawa 55's Avatar
Vehicle: SLK55 AMG
thank you for the help i will try to so it later on today and will post what happens.
Thanx again DAN.
Regards,
M.Jawa55
M. Jawa
2006 SLK55 AMG
Old 11-06-2006   #4 (permalink)
MJawa 55's Avatar
Vehicle: SLK55 AMG
thank you DAN everything is working amazingly.
Regards,
M.Jawa
M. Jawa
2006 SLK55 AMG
Old 11-06-2006   #5 (permalink)
Vehicle: 2006 Slk 350
Other Toys: Lots of ATV's
Glad everything is working. If u have more problems let us know, as mine works now but didnt at first few times I tried programming it. The basic install stuff is in the manual, but we know all who to ask if we cant figure it out!
Old 11-06-2006   #6 (permalink)
Alright mate glad to help
Old 11-07-2006   #7 (permalink)
MJawa 55's Avatar
Vehicle: SLK55 AMG
DAN
the setup works once after setup then i would have to set it up again in order for it to work. i might be setting it up wrong
M. Jawa
2006 SLK55 AMG
Old 11-07-2006   #8 (permalink)
Default Sync to intellicode garage door opener
Originally Posted by MJawa 55
DAN
Mjawa, when you press the remote control button (the one you programmed) in the car does the red LED flash for 2 seconds and then become constant?
If it does then the opener to the garage door in your building uses a rolling security code (called intellicode in the US). In which case you need to find out if you can access the "training button" on the garage door opener.
To program or sync to an intellicode opener (make sure no person or car will be in the way of the operating/moving garage door):
1. Press the training button on the opener, a training light on the opener will usually be lit or flash.
2. Immediately return to the car (you only have 30 seconds).
3. Press and hold for 2-3 seconds and then release the specific button that you had programmed (in the car).
4. Repeat step 3 (some openers require you repeat step 3 a third time).
Some openers will operate as soon as Step 3 is done 2x or 3x (confirming a sucessful sync). Other openers will flash their light. Press the programmed button in the car to confirm operation of the garage door opener.
Wait a few minutes, press the programmed button in the car to reconfirm that it will operate the opener a second time.
I hope the above helps and works (mainly useful for HomeLink type systems).
Old 11-08-2006   #9 (permalink)
There you go man its what he said.
Sorry should have mentioned it but totally missed that page out in the pc
Old 11-08-2006   #10 (permalink)
MJawa 55's Avatar
Vehicle: SLK55 AMG
Thank you etyu for the info, Dan dont worry about it. once again thank you guys for the help.
Regards,
M.Jawa
M. Jawa
2006 SLK55 AMG
Old 11-08-2006   #11 (permalink)
Regards,
M.Jawa
You're welcome M.Jawa. I am glad to be of help. Let us know if the above procedure worked or helped.
NOS Setup questionable. tungster Performance MODS for the R170 6 11 Hours Ago 08:46 PM
Garage Door Opener Mod DesignoSLK General Discussion 8 04-15-2008 08:26 AM
Update on my NOS setup tungster SLK R170 General Discussion 13 03-27-2007 11:16 PM
Adding garage door opener, can it be done? aquascape SLK R171 General Discussion 9 07-27-2006 12:04 AM
SLKWorld 2006-2009
